Best 60lb injectors
i have so many other little things i have been working on with it , i have put the fuel system on the bottom of the list, the reurnless isnt working bad right now , its staying right around 55 psi @ wot so its not to bad, im waiting to see how much it drops when i spray the wet shot though. im just using a magnavolt and a walbro 255 lph.
Don't forget to add that they are not a direct bolt-on injector!!!
You will need pigtail adapter to hook up your trucks injector wiring to those injectors.
The fuel rail will also need to be modified to allow these taller injectors.
Jim
Jim
