Best MAF to run
What happened to the SD tune? Was it not working out? Reason I ask is because I am considering a SD tune for my radix'd 03 SS. Just curious is all. I would think you could pick up a stock MAF for cheap around here.
Dave
Dave
Originally Posted by silverbrick
theres no point to get a MAF thats bigger than your throttle body, id say just get whatevers cheapest
In his sig there is a Nick Williams 90mm throttle body.
Dave
Dave
Dave
Trying to correct lean tip-in condition when I go into boost. I've been told that I can still run a 2 bar tune with a MAF, so I want to try it and see what happens.
Originally Posted by nightrunner
now that i think about it the gto (or any ls2) maf should be 90mm since the tb is 90mm...
