best style cam?
Split, in almost every circumstance. In stock form, the exhaust flows around 70 % of the intake value, (at least on 243 heads) so the extra exhaust duration is needed. Unless you have a completely unrestricted exhaust (LT, cat-less, dual setup) you're not going to reap the benefits of a single pattern.
Well i've seen good dyno's of the single pattern 220 cams. I'm gonna run lt's, catless, single 3" into magnaflow, getting a valve job and a bowl job done on heads.
So your saying to go with the LSr split?
Comp said single pattern cams were good mid-range cams
