Best way to delete cats
Old 07-06-2005 | 12:28 AM
thunder550's Avatar
High on diesel fumes
Default Best way to delete cats
I have ASM headers and Corsa exhaust....seems like the pinch point is the y-pipe and cats. Plus, I'm getting up there in mileage (96,000). I want to get rid of my cats but keep the look legal since I have to pass smog this coming year (AZ just does a visual and checks the PCM for codes). Should I just gut them, or are there look-alikes I can buy, or what is the best way to go with this? Obviously I need sims, I know that already....
Thanks!
Old 07-06-2005 | 06:53 AM
one03sierra's Avatar
Formerly one92rs
Talking
get brian to send a pcm with them turned off and gut them if you need a visual inspection.
Old 07-06-2005 | 08:57 AM
white1's Avatar
Shove a pipe thru them.
Old 07-06-2005 | 10:28 AM
FILE's Avatar
Put them off and run straight pipe.
Old 07-06-2005 | 11:18 AM
SBChevrolet's Avatar
Hes got to pass a visual I cut one side off and shove somthing though them but when you cut it off do it at a angle or make a jagid cut or somthing so it will only fit back togeather one way and everything will line up when you put it back in.
Old 07-06-2005 | 04:02 PM
thunder550's Avatar
OK so running a pipe through would be the best? Is the stock pipe size going to be a restriction between the headers and exhaust? I thought that it was a smaller diameter than the headers, but I could be wrong. I was thinking a bigger aftermarket set of cats or fakes, but if the stockers will work just as well then hell yeah.
Headers are 1.75" primaries, but I don't see any specs on the collector diameter.
Old 07-07-2005 | 03:07 AM
thunder550's Avatar
Anyone?
Old 07-07-2005 | 09:28 AM
TG02Z71's Avatar
Wish I knew where to get some fakes too just in case i do ever need an inspection.
My plan now is to buy two 12" sections of stainless 2.5" diameter tubing and just replace the cats with that.
Old 07-07-2005 | 09:46 AM
white1's Avatar
I have a set of gutted cats I got from someone. I am just going to weld in a piece of 2.5" exhaust tubing, and weld that in place of my factory cats.
Old 07-08-2005 | 03:26 AM
thunder550's Avatar
OK sounds like that's what I'll end up doing too. Thanks.
madmann26
04-29-2020 10:17 AM
Chewy07
11-14-2015 10:46 PM
BlownHD
10-03-2015 01:24 PM
Wolftrk99
10-02-2015 09:17 AM
02AWDAWSDenali
10-01-2015 06:08 PM
