Big Block Swap???
Big Block Swap???
Hey Guys,
I have a 2006 GMC Sierra RCSB 5.3L w/ 4L60E trans. I'm wondering if swapping in a BBC is possible. I know I'd have to modify the fuel system, cooling system, ignition system, exhaust system, but I'm wondering what else would be needed. Would I need to change engine mounts? Will the 4L60E bolt up to a BBC? Thanks Guys!
darkirish63 (03-25-2020)
High on diesel fumes
BBC isn't worth it IMO...if you're going to big cubes go with a well-built 408 that will drop right in. All you'd have to change it the tune. And probably the tranny, I doubt the 60E would hold up for long. You'll get just as much (if not more) power, and better mileage.
Why do such a slice job on a basically new truck. Go with a LQ4 or LQ9 6.0L with a cam, tuning, stall converter/trans. mods, and other supporting bolt-ons. You would probably forget about that BBC quick.
5 year bitches!
look into the 01 with the HD conversion. that guy put a 8.1 BBC in it. he used two trucks. a HD frame and a 1500 frame to drop the 496 down in it
but like others said its pointless. you can get 427 factory cubic inchs with small block lsx
