big tex or other that sprayed out of the hole on stock tranz
i dont have the cash to do much with this new beast till i get plates and all that but i do have a nx kit sitting here. i remember big tex spraying out of the hole and geting some good times, was that on a stock tranny and stock converter? if this thing will take a 125shot i may have to spray it. if i can't spray out of the hole i don't see the point though, it takes days to get up to 3000rpm now.
BTW. i think i will do some kind of huge shot on the 4.8 once i get a tranny in there, thinking a 150wet with the nx and then maybe a 100dry, just have to get a couple of parts to make that work . i have a pump. i bet that isn't enuff to blow it up. need to stage it or have a stall for sure too.
Banned
Re: big tex or other that sprayed out of the hole on stock tranz
you can spray it outta the hole...i spray a 125 on mine from a dig several times.
you should have kept that old 6.0/tranny combo and dropped it into this truck.
Adkoonerstrator
If you're gonna get a converter and spray it outta the hole I think you need some badass 20" wheels and tires for it. Hmmmm...what converter should you get, PYE3600.
$925?
