Bigger intercooler results!!!!!!!
Old 08-04-2004 | 06:25 PM
  #21
Black Blown 02's Avatar
Originally Posted by BlownAlaskan
send me the link to purchase that thing bud. Also, where did you get those blue turbo connectors? Did they come with the cooler? I get to go home from Boston in a week... I can't wait to drive my truck again. I ordered one of the vortec air intake kits for the 2004 ss. I'm gonna see if I can't adapt it to get into the charger....
Congrats on the install!! That is an amazing gain... guess it says something about the stock ATI setup.
This is the link to the GP where the picture of it is.
https://ls1tech.com/forums/showthrea...hlight=griffin
Just E-mail Tom at ls1speed and tell him you want-- CS-000AE-1
Mine took about 6 weeks to get, and cost around $600 after shipping.
I had a length of 3"ID silicone laying around the garage that I got at a local hose supply store.
I hope you can make that Vortech intake work. That will be sweet! How much did they charge you?
Old 08-04-2004 | 06:29 PM
  #22
BlownAlaskan's Avatar
Friggin' expensive... It was like $300.00. But the thing is... If it works like I think it probably will, totally worth it. I will for sure let everyone know one way or the other.
Old 08-29-2004 | 02:22 AM
  #23
NOSjohn's Avatar
Restricted User
Great results! I have a D-max IC if anyone wants me to take pics to see it or compare it to an intake or I can compare it to my truck. Also, if anyone wants it, they can have it cheap. I won't be putting my bigger turbo on until next summer and won't need an IC until then.
Old 09-27-2004 | 03:24 AM
  #24
lm7's Avatar
lm7
id like to see pics of the dmax intercooler anyone have any sort of idea how much better the dmax cooler woulb be oppose to the ati one...sorry i dug up this old post i just got back from logging my newer intake setup and venting the bypas valve making it a BOV went from 47lb/min to 51lb/min still only seeing 6-7 ish lbs of boost i say "ish" cuz it could just be my eyes wanting to see that right at my shift point im shifting at about 5670rpm right now... i want to see more air damnit!!!! oh iats with an ambient of about 59 were in the low 60s idling and crept up to about 106 on a 0 to 120 blast.
Old 09-27-2004 | 09:30 AM
  #25
I'm sure a D-max cooler would work way better than the ATI. I didn't realize how bad the ATI was until I put a better one on.
The lb/min are what you should really be looking at. My boost barely went up 1 psi with the new cooler, but my lb/min went up by like 11. The charge is so much cooler and more dense, that the airflow goes up a ton but boost doesn't change that much.
Old 09-27-2004 | 12:20 PM
  #26
lm7's Avatar
lm7
the intake i made was totally useless it seemed like a good concept but i gained almost 2lb/min by taking it off to my current setup im working on relocating my battery but right now the best thing to do is throw a pvc 45 degree on the end of the rubber 45 off the blower to get the filter off the headers my iats barely went up but i flowed a lot more air......seth from cmotorsports put it best......"you can blow through a straw in pretty much any position its bent but you cant suck through it"........ anything more than 11 degrees on the intake side becomes a restriction....so the shorter and less harsh the angle the better.
Old 09-27-2004 | 12:37 PM
  #27
I just replaced the 45 with a 4" rubber 90 and stuck a bigger filter up into my cowl hood. It seems to work well.
Old 09-27-2004 | 12:58 PM
  #28
lm7's Avatar
lm7
that should work really good i was thinking about that but i have a stock hood...maybe il throw some washers on it
Old 09-28-2004 | 08:04 AM
  #29
2dozen's Avatar
02: Not sure where the mass air is in relation to the intercooler but the iat is in the mass air. if its seeing the cooler air from the intercooler swap it may be richening the a:f. the truck probably never spent that much time at that iat temp and was tuned a little rich there. just a theory.
$A_Money$81
03-27-2023 10:25 AM
turbo6c3
10-05-2015 06:11 PM
old motorhead
09-29-2015 08:22 PM
bluebommer07
09-20-2015 08:42 PM
Alco
09-04-2015 04:08 PM
Quick Reply: Bigger intercooler results!!!!!!!
