biggest cam with Z06 springs???
Old 02-26-2007, 10:38 PM
BlackPearlZ71's Avatar
Default biggest cam with Z06 springs???
wuts up guys!! i was wondering, what is the biggest cam i can put on my truck since i'm currently running with Z06 springs because the previous owner left them on wen he had a cam on it...he had the tr220/220, .551/.551, 112LSA...i want to put the exact same cam back on but I was just curious if i should keep them or go with the 918 springs. would i see any difference in cam performance with those springs???....thanks guys!!!
Old 02-26-2007, 10:55 PM
kbracing96's Avatar
I believe you can go to .570 lift with Z06's
Old 02-27-2007, 12:20 AM
yeah i know the springs can sustain the cam i wanna get cus wen my friend owned my truck he ran that same cam with those springs...im just curious wether i'll get better cam performance with the 918springs or if it will be the same thing.
Old 02-27-2007, 07:27 AM
SS_bnoon_SS's Avatar
If you go with a .570 lift cam there will be no performance difference between the Z06 springs and the 918 springs. Unless you're planning on revving it above 7,000 RPM, I would just use what you've got. If you are revving it higher, then I would go with 918's or better just for the added control at the extra high RPM.
Old 02-27-2007, 08:15 AM
11 Second Truck Club
bluecajun5.3's Avatar
you might be fine with the zo6 valve springs.
i'd say stay under 6500 with them and you should be good.
Old 02-27-2007, 01:31 PM
so i should stick with my Z06 springs then???
Old 02-27-2007, 01:44 PM
it's your choice but i would go the 918's route just to have that extra insurance.
you never know when or if you'll hit the fuel shut off at say 6800.
Old 02-27-2007, 03:10 PM
Coban's Avatar
I would use the Z06 springs.
Correct me if Im wrong, but you wont have to baby the z06s like you do the 918 before they are warmed up. Thats a pain in the ***. I bet the z06s are quieter too.
Old 02-27-2007, 08:16 PM
funny my 918's sound like stock valve springs under the hood.
Old 02-28-2007, 01:40 AM
12 Second Club
00BlueTA's Avatar
Quick Reply: biggest cam with Z06 springs???
