BigKid, hook me up with something
Old 02-03-2005, 10:09 PM
slowprocess's Avatar
Default BigKid, hook me up with something
Kenny, where did you say you got your intake elbow from? What size is it,etc. Did you get the clamps from the same place? I'm going to do something about my current airtube setup. John, you should be happy I'm finally going to do something about my current one.
Old 02-03-2005, 10:19 PM
BigTex's Avatar
I'm not sure what BigKid did with his intake, but hee is what I was using:
The elbow is a 90* mandrel bent exhaust pipe that I cut to the right length than painted gloss black. Used a 45* PCV part from Lowes and a K&N filter on the end of the MAF.
Old 02-03-2005, 10:40 PM
02sierraz71_5.3's Avatar
man that looks nice for a custom setup, good idea
did you have any problem fitting the maf in the pipe
how did you clamp it down I wouldnt think you could put enough pressure on a hose clamp, you must of heated the metal a little to make it more maleable whats that called where you run a flame over the metal to align the atoms? I saw it on a bike builder show with guys working metal.
Old 02-03-2005, 10:52 PM
That's a really clean looking setup Richard!!! What size exhaust pipe and pcv pipe is that?
Old 02-03-2005, 11:00 PM
BigTex's Avatar
Its a 4" metal exhaust pipe. I bought it from an exhaust shop. Its the exact same size diameter as the outside of the TB, so they butt up against each other. I uses a 3.5" or 4" rubber fernco type connection from lowes or home depot to connect the TB and pipe. The PCV is 4". It wasn't hard to make, but I did have to buy several parts from home depot to test and try. Ended up with a bucket of misc parts after it was over.
Another view:
Old 02-03-2005, 11:03 PM
Keith's Avatar
BigTex - Are you using it with the Radix now?
Old 02-03-2005, 11:04 PM
redaddiction's Avatar
Where did you get the mandrel bent 90 ? Was it somewhere local because I have had no luck finding one local.
Old 02-03-2005, 11:09 PM
FormerVendor
KLUG'S SS's Avatar
Hey slowprocess is this what you are looking for http://shop.airflowonline.com/Merch...ategory_Code=9D
saw this in a thread earlier.
Old 02-03-2005, 11:13 PM
BigTex's Avatar
Yes it was local. You know where your buddy Matt got his exhaust done in Irving, the wheel shop. I was in there once and saw the pipe and thought...hmmmm that might make a very good intake pipe.
Not using it with the Radix currently. I may use parts of it to improve on the Radix stock intake.
Old 02-03-2005, 11:15 PM
FormerVendor
KLUG'S SS's Avatar
Damn page isn't working if you click on shop airflow online and then go to rubber hoses and then 90 degree elbows they have one that goes from 4" to 3.5". This is what I was thinking about for mine.
Quick Reply: BigKid, hook me up with something
