Billet Highflow Fuel Rails Now for Truck Intake
LS1Tech Sponsor
We now have our Billet High Flow Fuel Rails to fit the truck intakes with standard large injectors.
We are now offering Billet High Flow Fuel Rails and want to do a special intro offer. These are smooth fully polished Billet aluminum rails that bolt on to stock locations on the LS1 and LS6 intakes. Work With stock or aftermarket injectors. Can also be ordered with mounts for under rail direct port Nitrous kits.
Nasty Performance Billet Aluminum High Flow fuel rails $175.00 and free shipping
Same fuel rails with all hardware and line to bolt directly to the stock fuel lines $285.00 and free shipping includes a rail mounted pressure gauge
(trucks requier an added fitting and a presure regulator)
Happy motoring Nate
Happy motoring Nate
Banned
Re: Billet Highflow Fuel Rails Now for Truck Intake
PICS!!!!! this is a pretty good deal for us truck boys....about time someone started hookin us up. thanks Nate
how about the fittings for a bigger feedline coming into the rail? would it be a easy swap for bigger? I guess if we could see a pic it might be a bit easier on us.
Banned
they look very nice, and the lines are a bit bigger than stock. actually they are much bigger. i believe they fit either size injector depending on which manifold they're mounted on.
Moderator / Sponsor
seems a bit expensive when you can buy two extruded ford mustang 5.0 rails and a few pieces of braied hose and such for under $100. What do these look like?
Banned
their price is pretty competative with the other people selling LS1 billet fuel rails. will the 5.0 rails bolt right up to our manifold, and is it a good looking piece like theirs?
Moderator / Sponsor
The 5.0 Rails are the same injector spacing and same insertion angle. They will require you to bend two mount brackets (simple 90* with two bolt holes) and use a few AN fittings and some hard or soft line. My only curiousity is which regulator are they using or are they reusing the stock in a machined perch?
Pix would be nice Could still be a good deal if its engineered well.
LS1Tech Sponsor
http://www.nastyperformance.com/fuelrail/fuelrail-1.JPG
http://www.nastyperformance.com/fuelrail/fuelrail-2.JPG
http://www.nastyperformance.com/fuelrail/fuelrail-3.JPG
http://www.nastyperformance.com/fuelrail/fuelrail-4.JPG
http://www.nastyperformance.com/fuelrail/fuelrail-5.JPG
These are the same rails on a LS6 intake we have a new mount that works on the truck intakes. And you will need to add a external regulator.
We can also setup a complete fuel system for your vehicle. These rails will accept up to -10 line. They bolt directly to the manifold using an F-Body style injectors. We make 5.0 rails also and the mount is way differant not sure you could get it to work cleanly. And as far as price our ford 5.0 rails are $175 also and we use well over $100 in fittings and braided lines. It adds up quickly.
Nate
Nate
