Blew my transmission
Old 10-14-2004 | 03:54 AM
  #21
BADMOFO's Avatar
Cuz I AM a BADMOFO
Originally Posted by snoman
Pull a real load with a high stall up a hill on a hot day with A/C on and you cannot always use locking converter becase load is heavy. You live a sheltered life. I have seen Ford power strokes with automatics overheat and blow oil backing a heavy load up a grade. None of my SUV's or truck with automatics go without a aux cooler and I have one tranny 25 years old and still going strong because of it and it has had a wicked life too. I have little doubt that the 700R4 in my burb would not have lasted 170k and 15 years and still being going strong if I had relied on its stock cooler on a dozen plus cross country trips and traviling through southwest passes heavily loaded in summer at 100 degrees plus with A/C on!!! It was out there last year and it is going back again next year too.
If I were planning on pulling anymore then that I would have gotten a bigger truck! And BTW, what kind of nut joins a forum such as this less then 2 weeks ago and already has 239 posts about nothing helpful at all??? 22.97 posts per day? I think you need to check into an internet re-hab...as you definately have a problem with excessiveness!
Old 10-14-2004 | 05:46 AM
  #22
one03sierra's Avatar
Formerly one92rs
Talking
amen to that. he is the one that wants us to use fuel line for our tranny cooling lines also.
Old 10-14-2004 | 08:25 AM
  #23
marc_w's Avatar
Sorry to hear that.
I'm with JamesB - Heat didn't get you, a mechanical failure from shock/stress did...
Do you know how many washers were put in the 1-2 accumulator?
Old 10-14-2004 | 09:04 AM
  #24
thanks for all the replies, i'm still trying to decide which transmission will work for me, i'm looking at the flp level 4 4l60e and 65e and the dr. evil street evil. I think since i'll be upgrading the trans i'll get something that will be able to handle a 6.0 swap in the future, will I be able to get by without a 4l80e and still swap a 6 liter and spray a 100-150 wet shot on it? I'd rather not go with a 4l80e because of the extra drivetrain power loss. I'm not sure what kinda washers were used but i know the shift kit was set up at the lowest level possible (least hard shifts), even with the extra stress on it from the shift kit it doesn't seem like it should crap out so soon, guess I just got unlucky.
Old 10-14-2004 | 09:12 AM
  #25
marc_w's Avatar
Damn... I've got a Transgo, vette servo, and metal accumulator going in this weekend. I was going to run the lowest setting because I don't want hard shifts...
Old 10-14-2004 | 09:20 AM
  #26
Marc- You should be ok as long as you keep the line pressure down which can firm up the shifts, ie. don't use a programmer/custom tune to firm it up too much, and you might leave in some TM. With the 65e you should be in alot better shape than me to begin with though.
Old 10-14-2004 | 10:23 AM
  #27
BigKID's Avatar
Originally Posted by BADMOFO
...Has anyone else experienced trans temps in the 240 range as Snoman is talking about in their truck??
Right before I chunked all of my planetaries, mushroomed the input shaft into the drum and tosted my band and clutches. It wasnt because I didnt have an aux cooler though, I have one of the big B&M Supercoolers. It was just that tranny's time to go.
Fastsprint02... go ahead, bit the bullit and get a built tranny. I am currently on #3 stock replacement. The first two only had vette servos in them. This one got a transgo right after it was put in and it seems to be holding up better than the others but I belive the 3-4 clutches are starting to go. So I am planning on a rebuild/buildup soon. btw.. the only reason I went with sertas before was because they were convered under warranty.
Old 10-14-2004 | 11:37 AM
  #28
TigerFan187's Avatar
Originally Posted by sawedoff
Here try these guys. They offer all the parts to bullet proof a 4L60E. I thought I'd pass it along. I wish they'd become a sponsor.
http://www.transmissioncenter.net/4L60E.htm
If I were you I would stay away from Performance Transmisison(transmissioncenter.net). I live about 15 miles from them and let sjust say they arent known for being too honest. They have a Better Buisness Bureau file that isnt to shabby-Ive seen it. My buddies Dad tried to get a 3000 TCI stall installed from them and lets just say after the 3rd time they installed a Midwest 2200 and (2) 2600 he sais screw it. He also paid for each one and the labor for all 3 times.(I have no clue why). Their website will draw you in but dont let them fool you. I know like 1 or 2 people on here have gotten parts from them but I wouldnt get a tranny buitl by the-who knows what kind of parts they would use. They also must be real good friends with the local PD because they are always there!
Old 10-14-2004 | 11:50 AM
  #29
STOCK_SUCKS's Avatar
Question Shifting
I Have A 00 Ec 4.8 And I Want To Firm My Shifts Up A Little And I Was Thinikingabout Billet Or Vette Servos Int And Od And A Trans-go Atthe Lowest Setting. I Havent Removed Any Tm And Probably WONT For A While. This Is A Daily Driver With Almost 75000 Miles On It Will It Hurt Anything
Old 10-15-2004 | 11:36 AM
  #30
O3GMC's Avatar
12 Second Club
no it wont hurt anything.....and also....isn't kind of a PITA to capitalize every word? just wondering
Quick Reply: Blew my transmission
