Blower Cams
Originally Posted by SportSide 5.3
Remember this. The lobe seperation angle is "A" key in idle quality. Take this camshaft.
210/210 @ .05, Comp Lobe. With a lobe seperation angle of 115*, it has -20* of valve overlap @ .05 valve lift. Tightening the lobe distance to 110* creates more overlap... -10*. Take a look at that chart. It helps. Move the seperation closer, and you see how the lobes overlap. Move the seperation apart and you have less overlap.
So for example, a 220/220 on a 115lsa, may have the exact same idle characteristics of a 210/210 on a 110lsa.
Simply put: Overlap = duration vs. lobe distance (lsa)
whats the calculation for overlap?
Originally Posted by Flyer
Personally ... I still don't like the huge split going on there knowing your gonna be putting headers on there. I would go with the 218/224 without a question or second thought. The only 2nd thought I might have would be going to something a little bigger.
There will be plenty of power under the curve with the blower on top.
the second is Vinci's 045,
"THE TRUCKER"
STREET / STRIP / POWER
RPM RANGE 2200 TO 6000
TUNING REQUIRED
POWERFUL CHOPPY IDLE
DYNAMITE WITH A WHEEZEr.
This is my 3rd serious contender:
Thunder Racing Custom "Old Man Truck" Camshaft - 214/220 .600/.525 115+2 LSA This is the perfect cam for someone looking for a stock range power band and stock sounding idle. Significant horsepower gains throughout the RPM range. No computer tuning required.
Nope you had it, I just wanted to clear it up that overlap is the main cause of the bad idle quality, and not lsa.
Some think that a camshaft must have a 115* lsa to idle well. This is not the case. Sorry if I was soap boxing.
You can use (Intake Duration + Exhaust Duration) / 2 - (LSA * 2).
Ex.
210/210 on a 110lsa
210 + 210 / 2 = (210-) 110 * 2 = (220) = -10* of overlap @ .05
Ex.
210/210 on a 110lsa
A wide lobe seperation is a sacrifice of power for a decent idle quality. Even with a blower camshaft. I really don't think the radix is creating enough boost where overlap is a big concern. Especially with the emissions in Cali. Overlap equals power.
how much overlap to you recommend?
