Blower Cams
Old 02-23-2005, 11:23 PM
  #31
what a rush!
moregrip's Avatar
Originally Posted by Lone Chev
Getting this thread out of the dead--- Moregrip what cam did you end up going with? And how do you like it.
still researching but I have some favorites
Old 02-23-2005, 11:26 PM
  #32
Lone Chev's Avatar
Any new results? Other then the ones named in this thread so far?
Old 02-23-2005, 11:29 PM
  #33
what a rush!
moregrip's Avatar
Lingenfelter GT2-3 and GT7
a Crower Grind and the Cam Motion Grind.
I suppose the Crower is the only real new one I'm considering.
Old 02-24-2005, 04:56 AM
  #34
Sport Side's Avatar
Here's a bit of Q&A I had with a quite intelligent fella.
I see posts repeatedly about how the lobe seperation angle on a blower motor should be inbetween a 114-119 degree angle. That is total bull **** in my opinion. Knowing it's all about the valve events, the lsa idea doesn't make much sense at all. What is your opinion on lsa, besides it being a by-product. Have you ever cammed a blower motor and used a narrow lsa?
Blower LSA...Ha! As you say, it's a by-product. The more overlap you give a blower motor, the more power you'll make, just like N/A. You just don't *need* as much overlap to make power....since upping the boost 1psi would give more gains then 5 degrees of added overlap.
I'm coming around. I get what your hinting at. It almost seems the best cam would be a stockish one, with rearranged valve events. Or something that can keep the power range down in the blowers working area. Bump duration, take down the lsa for the suited valve events, but then that gets to the beginning paragraph and overlap.
Yes, you should design a cam that is ment to work in the 'sweet' spot of the blower/motor combo. Small, more aggressive lobes on a tight LSA keeping near the stock IVC/EVO .006 events will give great results.
Old 02-24-2005, 04:05 PM
  #35
what a rush!
moregrip's Avatar
Originally Posted by James B.
Hey guys, with a blower motor overlap has to be minimzed or it will bleed off boost and unburnt fuel. High LSA, good lift biased heavily toward exhaust, and minimal overlap.
what overlap range is considered minimized?
Old 02-24-2005, 04:19 PM
  #36
Sport Side's Avatar
Overlap increases cylinder pressure. Boost increases cylinder pressure.
More boost requires less overlap to make a given cylinder pressure. That certain cylinder pressure being the desired power. If we want X amount of power. And we add a blower. It doesn't take as much overlap to get us to (x).
Perhaps the internet hype has raised the "no overlap" scare to a far far extent. People are so affraid of blowing boost out of the tail pipes they've limited themselves to no tighter than 114* lsa, on ANY 2 given lobes.
Why? Is it really necessary to decrease overlap on a small grind w/ low boost?
Old 02-24-2005, 04:22 PM
  #37
what a rush!
moregrip's Avatar
Originally Posted by SportSide 5.3
Think about it.
More boost requires less overlap to equal a given power. Perhaps the internet hype has raised the "no overlap" scare to a far far extent. People are so affraid of blowing boost out of the tail pipes they've limited themselves to no tighter than 114*, on any 2 given lobes.
Why?
ok, I'll think about it while I'm washing my truck
Old 02-24-2005, 04:24 PM
  #38
Sport Side's Avatar
Smile
wash mine please.
Old 02-24-2005, 08:41 PM
  #39
I finally selected the comp cam 212/218 114LSA. The folks at Comp cam thought the GT7 would build up too much compression and limit the fuel to race gas.
Good Luck i nyou selection
Old 02-25-2005, 09:31 AM
  #40
what a rush!
moregrip's Avatar
that seems odd, LP says this is a daily driver easy. The only caveat was you should have a real good exhaust to run it.
Quick Reply: Blower Cams
