Blower Cams and Overlap
Compcams and Keith Craft came up with the grind they calculated the overlap at 0 at .050 I'll have to look at the cam card tomorrow to see what the actual valve openings are,the card is at my office.
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by moregrip
what are the valve events for this cam @ .006?
Naked, what are yours @ .006?
when you get a chance, email or post up your events ![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
Valve Overlap = -18.6 crank deg
INTAKE
valve open = -8.1 BTDC
centerline = 110 ATDC
valve close = 33.1 ABDC
duration = 205 crank deg
lobe lift = .32236 in.
valve lift = .54802 in.
lobe area = 23.19 in * deg
EXHAUST
valve open = 42.8 BBDC
centerline = 118 BTDC
valve close = -10.4 ATDC
duration = 212.4 crank deg
lobe lift = .31728 in.
valve lift = .53938 in.
lobe area = 23.64 in * deg
Originally Posted by Naked AV
Lobe Separation = 114 cam deg
INTAKE
EXHAUST
INTAKE
EXHAUST
this is what I show for your cam
Overlap: 18.50 degrees
Intake Duration: 221.20 degrees
Exhaust Duration: 233.20 degrees
Intake Installed Centerline of 102.50 degrees ATDC.
Exhaust Installed Centerline of 106.20 degrees BTDC.
