Blown three sets of collector gaskets.....
Old 08-18-2005, 11:28 AM
F8L Z71's Avatar
Copper ones worked well for my buddy. Both of use had major sealing troubl with the AS&Ms.
Old 08-18-2005, 01:46 PM
High on diesel fumes
thunder550's Avatar
OK thanks I just ordered a set of copper ones. Is there some kind of design flaw with the ASM's that keeps them from sealing well?
Old 08-18-2005, 01:49 PM
Truck addict
goshawk23's Avatar
good deal on the copper ones. i have had no problems with them at all. i was blowing gaskets out of my cutout left and right. finally went with copper on that and my headers and have had zero problems.
Old 08-18-2005, 04:44 PM
11 Second Truck Club
bluecajun5.3's Avatar
i use copper ones on my chevelle back home. haven't had a problem with them. they work fine even after reusing them
Old 08-18-2005, 08:54 PM
Flyer's Avatar
I've not had a header yet (TOG's or the 3 bolt flanges on my PaceSetters) that sealed up good. I'm seriously thinking about those header buddie.s
Old 08-18-2005, 09:17 PM
BigTex's Avatar
I went through several paper and metal gaskets until I tried the aluminum ones. My aluminum gaskets worked well until I installed the radix. At that point, temps and pressure made mine melt too. Copper worked better, but didn't seal up as tight.
I moved my ASMs to 3" ball / socket flanges and now have no problems. Much easier to work with and not even minor leaks.
Old 08-18-2005, 09:36 PM
PT's Slowest Truck
budhayes3's Avatar
Did you use those header buddy's or did you fab your own?
Old 08-18-2005, 10:41 PM
BigTex's Avatar
I bought a kit that had both sides. I cut off the existing 3 bolt flange, then expanded the header out to 3" diameter. Then I had to weld one side to the header and the other to the pipe.
Old 08-19-2005, 12:05 AM
thunder550's Avatar
Wow...I hope I don't have to do that.
Old 08-19-2005, 01:24 AM
11 Second Club
Grey Silver's Avatar
I run Ultra Seal gaskets and never have a problem.
Quick Reply: Blown three sets of collector gaskets.....
