Bolt-ons for NBS 99-06 GM fullsize
Old 12-21-2007, 05:28 PM
  #51
Mr. Obvious
nightrunner's Avatar
Originally Posted by camrs73
Might want to clarify this a bit seeing as it's often confused. The higher numerically gears (which are known as low gears) will get off the line faster. Lower numerically gears (known as high gears) are better for the highway/top speed.
correct. for example, 4.10 gears will get off the line better but will reduce top speed some. 3.23 gears would be better suited for the top end while sacrificing the take-off
Old 05-05-2009, 10:17 PM
  #52
Duramaxin14's Avatar
[QUOTE=nightrunner;3668886]BOLT-ONS11. Fuel
After doing some or all of these mods you may need to upgrade your fueling components.
A 255lph fuel pump is a popular upgrade.
http://www.texas-speed.com/shop/item...d=225&catid=10
Could i run this pump rather then that one?
http://www.pacificp.com/store/index....roducts_id=141
Also would i need some kinda regulator for the pump. With a stock spider injection intake what kinda pressure do i wanna see idealing and what kind do i wanna see @ WOT
Sorry for the newbie questions im trying to learn this stuff
Ps its a 97 chevy with the 5.7
Old 05-07-2009, 11:17 PM
  #53
Toadster's Avatar
why isn't this stickied?
Old 03-12-2010, 03:23 PM
  #54
Mr. Obvious
because it is linked in the mega-sticky at the top of the GM Engine and Exhaust Section
Old 03-15-2010, 04:50 AM
  #55
12 Second Club
AdioSS's Avatar
Didn't I read on here that a 2-piece driveshaft if safer at higher speeds (dyno) than a stock 1-piece?
Old 03-16-2010, 03:38 PM
  #56
Amedee's Avatar
i would like to know the answer to that also
Old 03-16-2010, 04:48 PM
  #57
13 Second Truck Club
grey matter 04's Avatar
yep thats the reason why the crewcab guys put a 2 piece drive shaft from an xcab in there crew
A long one piece shaft will flex at high speeds,there have been may explode on the dyno
Old 02-09-2011, 06:29 PM
  #58
Registered User
DJaeger's Avatar
Where can you find aftermarket Y pipes at?! with cats for a 06 silverado crew cab
Old 10-23-2011, 09:02 AM
  #59
03WhiteRCLB's Avatar
Anyone ever get worse gas mileage with a cold air intake? I put an AFE stage 2 dry intake on my 03 with the 4.8 and it seems i loss 1 to 1.5 mpg. Only other "mod" is a magnaflow in place of the stock muffler.1 to 1.5 mpg doesn't seem like alot but when ya have the 34 gallon tank like i do , you sure notice a difference. I used to get at least 300 miles on a half tank and don't even get that anymore. I drove 280 highway miles yesterday and i used almost a half tank. Any ideas?
Old 10-23-2011, 11:05 AM
  #60
neilownz's Avatar
Probably need a tune.
Quick Reply: Bolt-ons for NBS 99-06 GM fullsize
