Boost Gauge Install
Boost Gauge Install
I just received the Magnacharger Boost gauge. Which vacuum lines do you guys usually tap into? I don't even know if it matters. Is there anything I should do make the install easier? As far as the wires, just go into an accessory, right? It seems easy enough, just want to make sure. Thanks.
blownerator
Tap into the line that goes to your Fuel Pressure Regulator. There should be a metal tee included with the kit.
FlowmasterMufflers
07-22-2015 01:29 PM
