Borla Pro XS
Old 06-26-2009 | 02:46 PM
AndysC3's Avatar
Default Borla Pro XS
I am going to put some longtube headers on with high flow cats soon. And I'm thinking about changing out my Flowmaster 50 out to the borla pro xs. I am currently running duel single in/out with 3" pipes. Has anyone had any experience with this type of set up?
Old 06-27-2009 | 01:49 PM
No but Borla sounds good! Go for it.
Old 06-27-2009 | 02:36 PM
TX Tahoe Z71's Avatar
Had a single 3" Pro XS on my tahoe for a few years in place of the stock muffler. It sounded nice and quiet for a while, but finally burned out (when the sound deadening material in the muffler burns away) and was really loud after about 3 years. I would go with Magnaflow. Had a magnaflow on my bronco, then went back to magnaflow after the pro xs muffler and like it more. Had the one on my bronco for 5 years, never burned out.
Old 06-27-2009 | 02:40 PM
Bumpers's Avatar
Get the xr1 if your goin borla.. the pro xs is wuiet as stock just changes the tone a bit.. It would prolly sound really good on a truck with no cats
Old 06-27-2009 | 02:56 PM
AndysC3's Avatar
I wish I could run cat-less. But the state says I can't. Another ? Is there any benifit to running a y to a single in duel out? Or maybe a x pipe half way between the cats and muffler? Looking for the best sound/performance. Thanks for the advice
Old 06-27-2009 | 03:35 PM
dug's Avatar
dug
Banned
Im curious, whats the borla xs muffler look like inside? Is it a straight through design like the magnaflows?
Old 06-27-2009 | 03:46 PM
Yep, looks the exact same as the magnaflows inside
Old 06-27-2009 | 03:51 PM
dug's Avatar
dug
Banned
so they sound pretty similar to the magnaflows?
Old 06-27-2009 | 04:12 PM
It was explained to me by a muffler shop owner that they use different sound deadening material inside. Magnaflow uses a stainless mesh mix and borla uses something else that burns away over time, causing the muffler to get progressively louder (I discovered this first hand). The Magnaflow case is also larger in circumference.
Old 06-27-2009 | 05:11 PM
Bumpers's Avatar
I would go single 3" with the xr1 and it will be nice I promise there no need for true duals on a stock or almost stock truck. Single 3" might even wake it up a bit
