BOSCH PLATINUM or BOSCH PLATINUM 2
#21
Originally Posted by shandy294
I only have 11k so I'm still on the original ones. I've used Bosch Platinum +4s in my old 93 Civic with good results. Had them in for 60k and they looked good when I took them out. It seems to run a little better than with stock ones.
#25
Originally Posted by hefdaddy007
why would you go from stock ngk plugs in a honda to bosch??
Are you an expert at runs well in a Civic? I can accept that the Bosch ones don't run well in the GM Gen 3 truck V-8s...does anyone know why?
#26
It had Nippondenso originally (some apparently came with NGKs). I ran Champion Copper Plus for 45k. It has run well with those three different plugs in it. It seems like the P+4s have made it run a little better.
#28
most civic come with ngk's few com with nippon denso plugs. but the recommended plugs are ngk v power. and in the b16a and b18c1&c5 and b16b recommend the ngk laser platinum. i've had many civic friends run others and they just don't compete with the ngk's. i run ngk laser platinum in my civic with msd 6al and blaster II coil personally.
#29
Originally Posted by ridnlow
Just put NGK Tr55's in mine. I only have 70k miles on mine so i left the plug wires stock.. Ive heard way to many horror stories about the Bosch plugs to go with those.. I picked up my TR55's from Oreilys for 12.96.. Have fun with the the last spark plug on the passengers side..
i use a 1.5 inch extension for that plug. works good without too much sideways torque.
i have ran NGK's in my outboard motors for years. they are good plugs for marine and autos.
the copper NGK's are cheap and are supposed to work good too. they are only like $2 per plug or maybe even cheaper.
no reason to change out stock until after 100k miles, right? unless you have NOS or something
