Braided Steel Lines & Fittings
Looking for some information & guidance on using braided line & AN fittings. Which fitting can I use to get from a plain-end or flaired-end tube, to an AN fitting and then braided lines.
Use for example, cutting into the hard tranny cooling line and trying to run a braided line to an aux oil cooler. I know I can use some rubber hose & clamps, but how can I take it to the next level and get some braided line and fitting?
Thanks
Thanks
Formerly one92rs
Re: Braided Steel Lines & Fittings
i used rubber line. fuel injection hose and barbed fittings.you can use braided hose covers.but if you want to u can use steel braided lines. summit is more than likely got the fittings you will need.or look for a hydraulic hose place.
GXPJAY
02-13-2022 08:15 AM
Steve-O-08
04-19-2018 09:32 AM
GXPJAY
01-27-2016 11:45 AM
FlowmasterMufflers
07-17-2015 03:26 PM
mrgrim
07-08-2015 08:12 AM
