brake torque
pROBLEMS?
Originally Posted by JRsilverado
When you have 100% of the TM removed, does that take care of the abuse mode or is that something different? I had Allen remove all TM and It's still hard to spin the tires. I have 2 washers in my shift kit and I can't scratch 2nd. I have 3.42s and 285/60/18 GTIIs.
I had 80% removed, and now I hear a loud "clunk" each time my trans. shifts gears, so I dropped the trans and looked over all innards and stuff looks great....just sounds bad.
Originally Posted by Torque_Wrench
Hey, have you had any trans. problems with all of your Touque Mgt. removed?
i have a '00 ECSB 5.3, 3.42's, G80.
hypercrapper
K&N Fipk
255/70/16 liberator allterrains.
mine will spin pretty good from a dead stop up to 30mph.
and will power brake really easy.
but it is probably just the cheap tires. the back ones are pushing to be replaced! i dont get on the interstate if it rains thats just asking for trouble!
hypercrapper
K&N Fipk
11 Second Club
I have about 10,000 miles on my stock tranny now with the mods listed below and no Tq Mgt. It will still chirp them in 2nd and still shifts hard (knock on wood ) Only thing I have done is bumped up the line pressure for firmer shift up top and shift a 6200 RPM. BTW when is a good time to change your tranny fluid, I am at 25000 miles.
14 Second Truck Club
Originally Posted by StrokerAce03
I've done a few brake stands before but I always wondered, what kind of abuse does the rear brakes receive? I'm assuming that the pads wear quicker but could it damage the calipers and rotors?
I use line lock when doing a burn out. When building boost I actually hold the break to the floor and then floor the gas at the same time. At first I could build no boost. But then I did a set of Hawk pads in the rear and now I can break boost it to 9# on street tires. If you are looking for help doing a burnout, get some line locks. Problem solved.
Tim94gt
23
09-18-2015 04:51 PM
