Break in time.
Old 06-06-2012, 04:41 PM
Registered User
Team Paulie's Avatar
Originally Posted by DZZ71
My last 2 builds I fired it up let it idle till I got all the air outta the new injection pump and lines. Then played with the rpms a bit then went for a drive. I think I waited till 500 km before I went WOT. Also changed oil at after the first half hour I ran it. But that was for a diesel not sure if gas is the same
Old 06-06-2012, 05:15 PM
DZZ71's Avatar
I'm assuming it was done wrong? Lol and FYI both engines run great and have had zero problems.
Old 06-06-2012, 05:27 PM
TXsilverado's Avatar
theres a dozen different ways to break in an engine and i'm sure every one of them work just fine. i've never seen a modern race car broken in putting around a neighborhood though. straight to the dyno for some abuse
Old 06-06-2012, 06:58 PM
kbracing96's Avatar
Exactly! When I worked in NASCAR racing, motors were warmed up, checked for leaks, then 1/2, 3/4, and then full pull on the dyno. Full pulls till the torque didn't gain from one run to the next. That's how they new the rings were seated and it was ready to go racing!!
Old 06-06-2012, 07:25 PM
GREENSIERRA's Avatar
I have broken in countless motors, fire it up, check for leaks, make sure tune is in check and then WOT.
Old 06-06-2012, 10:02 PM
dick_landy's Avatar
I had mine at the track with 170 miles on the clock
Old 06-06-2012, 10:07 PM
Scrapin'4.8's Avatar
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
Apparently to these guys, this is no secret break in
Old 06-06-2012, 10:16 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Basically this is exactally what I do.
Warm it up first, inspect for leaks, check all fluids and take it for a spin. Basicaly work up to WOT as soon as Safely possible.
As I warm it up I let idle first to make sure nothing is gushing out or arcing then I take it to around 2000 give it a few small whacks of thew throttle to about 4000 then let off and check the temp. repeat the 2000-4000 until I get up to full temp and make sure the T-stat and everything else is working correctly.
As long as there is no major leaks or any thing that looks dangerous I take it on the road and get it on here and there down industrial streets were there are no people or traffic in case something happens. Once I know its good I let it cool all the way down, change the oil and filter, button up any lose ends, bring it up to operating temp, and shake it down some more on the Highway. Once I put 300-500 miles, I give it 1 last oil change before going to regular oil change intervals. But I always inspect it every few hundred miles to be sure everything looks good between oil changes until I put enough miles on to know it's good to go.
Always inspect the Oil Quality and level after to take it out and gradually space it out till you know its good to go between oil changes.
If it gets dirty fast or you notice it has an oil consumption issue Something is wrong and you need to find out why before its to late.
Old 06-06-2012, 10:58 PM
DZZ71's Avatar
Interesting link. I'm
Definatly gonna work mine harder off the start
For the next build
Old 06-06-2012, 11:59 PM
1994Vmax's Avatar
Heat and load seats the rings properly to the walls. This is accomplished relatively quickly and then it's just that downhill degradation to the end of the engines service life.
Get it hot and drive it hard!
Quick Reply: Break in time.
