Broke Crank Bolt
Broke Crank Bolt
So pretty much the worst thing that could happen did. When I was starting my cam swap yesterday while I was removing the crank bolt it snapped in half. So what are my options? Can it be drilled out? Do I have to pull the crank and have a machine shop try and remove it? Or is it pretty much screwed and I need a new crank?
I had the same thing happen with arp bolt. I had to replace the crank because it was to hard to drill out in the truck. To replace crank in the truck isn't to bad it just sucks.
