Broke Crank Bolt
Old 10-21-2010, 12:11 PM
I have a gauge for that
Atomic's Avatar
Wow, you broke the ARP bolt? That is impressive.
Old 10-21-2010, 12:14 PM
aaronmc's Avatar
I do what I can
Old 10-21-2010, 01:23 PM
11 Second Truck Club
fastrt's Avatar
ewww, damn!! i pulled some treads out trying to put mine back on, and broke a peice of all thread trying to pull the new pulley on the crank.
Old 10-21-2010, 03:36 PM
hirdlej's Avatar
Originally Posted by 53RUSSELL
To replace crank in the truck isn't to bad it just sucks.
This I would like to watch.
Old 10-21-2010, 03:47 PM
blsnelling's Avatar
And not have the crank all gouged up from the rods hanging everywhere?!!!
Old 10-22-2010, 10:30 AM
aaronmc's Avatar
So once I get the engine out how hard is it going to be swapping the crank? Pretty straight forward just time consuming or one of the hardest things to do?
Old 10-22-2010, 11:50 AM
1Bear's Avatar
I’ve seen it before when someone used an ARP bolt that was too long, allowing it to bottom out in the bolt hole, basically friction welding itself into the bottom of the bolt-hole. It too broke when trying to remove it, causing the need to replace the crank. The individual wouldn’t have likely even known, had the balancer been pulled all the way down, but it wasn’t and he was throwing belts faster than he could put them on.
Old 10-22-2010, 12:15 PM
blsnelling's Avatar
You'll want to have the replacement crank polished, install all new crank bearings, and plastiguage every journal, to make sure it's right.
Old 10-22-2010, 02:06 PM
Wearin' da big hat
00ChevyScott's Avatar
All you have to do is flip the truck upside down, duh
Old 10-22-2010, 02:30 PM
454navyss's Avatar
everyone knows that is the easy way to do it
Quick Reply: Broke Crank Bolt
