broken crank
Old 06-06-2004 | 12:10 AM
  #21
L-EATER's Avatar
11 Second Truck Club
Ok, sorry for the delay on the update. The crank was NOT broken, just broke the center out of the flywheel. I found that after I got the motor out Oh well, I enjoy pulling this motor every month or so!
I found a couple probs so hopefully it wont happen again. And I went ahead and put my forged motor back together so it is going back in with a fresh 4l80 and a Yank pro 3400. We will see in a couple weeks, I guess.
Anyways, I have learned that the 6 liter spacer and flywheel is necessary with the 4l80. I was running the 5.3 flywheel with no spacer. It will physically work, but what I didn't know is that the spacer not only serves as a spacer, but also as a crank pilot extender, effectively extending the rear of the crank, giving the converter snout something to center into. So my converter was centered on nothing but 3 little bolts and at almost 7000rpm it needs to be perfect!
My other prob was that I have been trying to run a trans case that was busted into 8 pieces at one time and was welded back together. It is evidently not 100% inline with the motor and that is causing major probs.
I should be back in business soon.
Old 06-06-2004 | 12:35 AM
  #22
Flyer's Avatar
Is that 6.o flywheel the same as the 5.3? I would think the spacer would be the only change needed, but I need to know for sure since I will be doing this very thing soon.
Old 06-06-2004 | 01:02 AM
  #23
L-EATER's Avatar
Flyer, No-the 6 liter flywheel is flat and uses a spacer. The 5.3 flywheel has curvature made in it so that the starter ring gear comes out in the same place as the 6 liter flywheel does with the spacer. So yes, the 5.3 flywheel will work with a 4l80, but like I said, not advisable cause of the pilot issue.
Old 06-06-2004 | 01:10 AM
  #24
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
The reason for the flywheel change is to keep the teeth lined up with the starter. They bow the flywheel differently; otherwise when you add the spacer you would be moving the flywheel teeth away from the starter.
It would be a shame to go thru all the work of the changeover and then just hear the starter zing but not engage.
Old 06-06-2004 | 01:11 AM
  #25
GREGGO's Avatar
I was thinking that would be possible then I read it. I'll keep that in mind if I ever go to a 4l80.
Old 06-06-2004 | 01:46 AM
  #26
Flyer's Avatar
Wow .. some more great info! John, I'll be contacting you probably next week about the harness. I will send you my ls1edit file if Allen can't help me out with it, I still haven't talked to him about it yet though.
L-Eater .. sounds like you had some messed up stuff going on. That's good advice for the next guy.
RustyD
05-23-2016 08:04 PM
SSpeeDEMONSS
10-03-2015 09:21 PM
Velocity1
10-02-2015 09:01 AM
trxmxzx
09-29-2015 08:42 AM
trevorh1
09-27-2015 09:47 PM
Quick Reply: broken crank
