Broken Manifold Bolts??
#22
Keep in mind that if you have a firmly stuck header bolt broke off flush in the head, it most likely cannot be removed.
Instead the easiest way is to drill out the center of the broken bolt and re-tap it to a smaller size with a bottoming tap. I had to do this during my header install, and ended up making it 1/4" instead. You are doing the opposite of a heli-coil basically.
zblee
63
06-10-2023 01:25 PM
JFortner5
08-20-2015 06:13 PM
