Broken off exhaust bolts
Baltimore Whore
Use a 3/8th nut, so that hole in it is about the same size as the bolt hole. Lay it open end up, so that you can see the stud ofthe broken bolt. Weld strait down so that it welds the broken bolt to the nut. USE A NON GALVINIZED bolt. It might melt the area around the hole some, but nothing that should cause issue, or that can't be cleaned up. I have done it a few times, with out issue..
