building a 5.3L 323
Old 10-06-2012 | 08:17 AM
  #21
sand man's Avatar
oh yes almost forgot
its not a 323 nor 327
its a 325ci
Old 10-06-2012 | 09:33 AM
  #22
RibeiroBJJ's Avatar
Praise The Lowered
Originally Posted by jrmchevyman
I'll try to help the guy out. He might just need some learning.
Every vehicle has drivetrain loss. Your stock 2001 5.3L was rated at 285HP at the flywheel from the factory. You typically see 20% drivetrain loss on a truck. 285 divided by 20% is approx 228 hp at the flywheel. So how did you double your hp without doing any internal work or add FI or nitrous? Just trying to help you out here.
So basically the only thing you did was add the programmer to the truck. The flowmasters don't add hp just sound and they are a restrictive muffler as it is. Flowmasters do sound good though. A cold air intake will pretty much add no power on a stock truck, you might of gained ~5hp.. With the handheld you probably gained another 10hp.
Take it to a dyno and get it dynoed, then you will have your base numbers. After that keep modding your truck until you are happy.
That would be 228 hp at the rear wheels..You started at the flywheel...
Other than that, I agree..You cant add up all the advertised claims and tell people thats what you have..You need to get your truck dyno tuned and will see you are closer to the 230 hp range...
Also there has not been "chips or eproms" in trucks since the 90's..Only a pcm/ecm that is programible via the obd port..and only factory FI vehicles/turbo diesels pick up 50+ hp from a re-tune..
Old 10-06-2012 | 10:09 AM
  #23
03sierraslt's Avatar
For starters welcome to the site, just so you know if your current mods are Diablosport, exhaust and intake then you are not making 410hp. You may want to do a little bit more research on cams, the ASA cam is no where near optimal for a 325ci motor in a truck. That cam is too big, also forget about the throttle body spacer as it is a waste of money. A good set of heads and a properly sized cam will help out tremendously but you have to plan out what you want to do. How high of a stall speed do you want to run torque converter wise? Plan to build up the transmission also.
its a 325ci
Yep, see my post above.
Old 10-06-2012 | 10:18 AM
  #24
jrmchevyman's Avatar
Thanks for catching the typo. I edited it lol.
Old 10-06-2012 | 10:30 AM
  #25
TXSZ66AVLANCHE's Avatar
According to my ricer math I'm making like 1000hp to the wheel minimum.
Old 10-06-2012 | 01:02 PM
  #26
darnie's Avatar
dam if you add both wheels thats 2000 to the rear " wheels" haha na hopefully dude gets on and can better understand what he needs to do to his truck to make it funner
Old 10-06-2012 | 09:31 PM
  #27
Isak81's Avatar
I suggest you go talk to Nelson Performance
10034 Roosevelt Ave.
San Antonio, TX 78214
They build these trucks everyday and will tell you what works best for your goals.
Old 10-08-2012 | 01:58 AM
  #28
sand man's Avatar
how much money you want to spend ? if you realy wanna make the 410 real you should get a turbo kit or a 6.0 + motor with some stout cam to get there
Old 10-08-2012 | 03:15 AM
  #29
texasglock23's Avatar
dat stacked chip
Old 10-08-2012 | 06:35 AM
  #30
Oh snap! Good catch I forgot that other wheel!
