Building an lq9, need cam advice
Check this link... guerra-group
You may already know it.
Usually only takes him 3 or 4 days to get back to you, but then you have to wait 3 or 4 months for EPS to get it to you. I'd suggest you do what some others have done... Have Pat G spec it and TSP grind it. I just had TSP grind me a new cam, ordered it Monday and got it Friday.
This is also an awesome cam, been a couple of others who ran this with good results too.
Fastest D1 Procharged Truck
ive got a 226-230 600/600 111+3 in my LQ4 with 243 heads ported by ADVANCED INDUCTIONS ran a 12.3@110 im pretty sure truck has a 12.1 or a 12.0 in it
heres a vid of how it sounds its not tuned so it stalled out at first http://youtu.be/EkJSJqkI2Io
I still think you could easily go into the 240's and 250's with the manual trans. Tyler (dirt track racer 81) daily drives an Lq4 with a cam in the 260's if I am not mistaken with an auto trans. Its all in the tune, and yours will be even easier not having to worry about a stall converter. Just my opinion though, I have never built a motor with that large of a cam so it may be best to talk with others that have, such as Tyler, and get their opinions before you pull the trigger. Oh, and he runs nitrous too which is what your planning on doing......
Try something like a 236 .602/242 .610 on XER lobes on a 110/111 LSA if you want lope.
Yoa can also check TSP's site in there cam section and spec your own. They have duration/lift/type of lobe all listed. Do some research and pick your own.
