Built 6.0- How Much Nitrous?
Old 10-30-2007, 09:35 PM
single digit dreamer
parish8's Avatar
for a big nitrous motor set up i would do a 2 stage. something like a 75-150 wet shot and a 200 DP shot. with pistons and rods, good fuel and tune i see a 300shot holding just fine especialy if you stage it.
i would also go with a seperate dedicated fuel system running race fuel just for the nitrous. with that much nitrous twin 10lb bottles or even 15lb bottles would be nice or you will be filling up every couple of runs. -6 nitrous line.
i just noticed you didn't ask for advice on a set up. just how much. 300+ if done right but dont waste you money on a crank.
Old 10-31-2007, 10:49 PM
sprayed8's Avatar
I was thinking on the lines of 250 and 300 if possible. has anyone else done a direct port kit? i'm just wondering what the installation is goin to be like so i can prepare for some tedious work. out of curiosity, i have a ZEX system now with the single wet nozzle and the controller with the solenoids built in, how much is a setup like this capable of sraying?
Old 10-31-2007, 10:55 PM
99Silverado5.3's Avatar
Set up right it will do 300 all day.
Old 11-03-2007, 06:15 PM
sprayed8's Avatar
would i be better off wih and LQ4 or an LQ9 block, is there any diference, if so what are they?
Old 11-03-2007, 06:24 PM
parish8's Avatar
lq4 is going to be cheaper. if your going to put forged pistons in it no point in paying for the higher cost lq9 since the only diference is the pistons.
Mr. Obvious
nightrunner's Avatar
no diff. in the block itself
Old 11-03-2007, 09:16 PM
sprayed8's Avatar
i am buying the motor from a salvage place through a truck dealership i buy alot of parts through so they are giving me a good price. they quoted me $850 for a 6.0 with 80000 miles. the price is for the motor, the harness, and the computer, basically a full drop in. is it worth spending that much or should i just try and find the block, crank and maybe the heads seperately for less since i'm gonna change the internals anyway?
Old 11-03-2007, 10:38 PM
parish8's Avatar
it would be best to get the whole thing. then you will get all the little stuff like covers, lifters, bolts, rockers...... long list. it is hard to piece a motor together.
Old 11-05-2007, 08:14 AM
sprayed8's Avatar
i am thinking of boring the motor like .030 over. will i need to get different heads to accomidate the larger bore or will the stockers be ok. if not, is it worth spending the money on new heads, and what heads can i use?
Old 11-05-2007, 04:09 PM
parish8's Avatar
stock 6.0 heads will work prety good. no problem with the overbore. good heads would give you more power if you got the cash but you dont need them.
Quick Reply: Built 6.0- How Much Nitrous?
