Built 6.0- How Much Nitrous?
#21
parish, you sem to be getting plenty of power out of your 5.3, would a 5.3 with all the same mods i was thinking of or 6.0 be able to to keep up if it had a big cam. i'm asking because i'm wondering if a more aggressive 5.3 would have beter fuel mileage.
#22
single digit dreamer
not sure. i think on a boosted set up you can nearly the same hp with any of the stock motors. 4.8/5.3/6.0 all good for 600+rwhp with a good tune and the smaller the motor the better the mileage.
on a nitrous motor i dont know if all of the motors would get near the same hp level.
#23
both nitrous and boosted motors wok on the same principle of simply forcing more air into the engine so i would think what goes for boost will also go fo nitrous but i'm not sure either. anyone else have a take on this.
#26
i was thinking more along the lines of maximum power output. i guess i should have said, since i'm looking to build a motor with decent fuel economy, can a 5.3 with a more agressive cam, bored to like a 383, handle as much spray as a 6.0, make similar max hp, but give me better fuel mileage?
#30
GFYS and STFU
If you want fuel economy go with the set-up with the smallest chamber size. 6L(364) is better on fuel economy than a bored and stroked (383) and a 5.3L will trump them all. Do what Tootall suggests, proven and simple and good fuel economy, and spray a little for when you wanted added power. Spray shot is doubled when in boosted applications, from what I understand, Parish would know more as he sprayed on 18 lbs 1/4 mile runs.
gavin2005
09-13-2015 09:04 PM
