built 6.0 injector size reccomendations???
Old 01-21-2007 | 08:08 PM
negativeswitches's Avatar
Default built 6.0 injector size reccomendations???
32lb/hr big enough for a 370 with ls6 heads and and ms3 up to 7k rpms or so
i know i know the ms3 on 113 is to big, but i want to try it since i'm going to get a sweet deal on it
i will prolly step down to a torquer v.2 eventually
-Erik
Old 01-21-2007 | 09:10 PM
IMO it might be pushing it a little but I am not really sure. All depends on what IDC you are comfortable with.
Old 01-21-2007 | 09:15 PM
onebadrubi's Avatar
if your still running the truck manifold, i hope your not if you spinning to 7k try the marine 44lb injectors.
Old 01-21-2007 | 09:34 PM
dirt track racer 81's Avatar
if you run the ls6 intake get some red top 30lb svo injectors..at 60 psi they are almost 36lb injectors
Old 01-21-2007 | 09:40 PM
litreddevil's Avatar
Banned
-Erik
dude i am runinf the 8.1 31 lbs injectors and i have a 114 lbs and i am spraying a 2 stage 100 then 125 are 150 so you will be good
Old 01-22-2007 | 11:57 PM
i got a good deal on a vic jr so no more truck intake
-Erik
thanks for the replies guys
Old 01-23-2007 | 08:58 AM
Tootall's Avatar
-Erik
keep us up to date about it
Old 01-23-2007 | 11:55 AM
ap2002's Avatar
I would go with the 42lbs,
I have the stock ones and they are @ 94%duty cycle.. Im going with the 42lb'ers to be able to spray mine safely...
GrooveCityZ71
08-31-2015 12:05 PM
FlowmasterMufflers
07-30-2015 05:03 PM
GMCtrk
07-17-2015 06:39 PM
jrplz
07-09-2015 12:07 AM
Quick Reply: built 6.0 injector size reccomendations???
