BUMP STOP GRIND. NEED INFO ON
Old 04-21-2003, 04:45 PM
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Default Re: BUMP STOP GRIND. NEED INFO ON
Yea...very nice...here's mine....
<img src="http://home.earthlink.net/~lalito/eddie/myride.jpg" alt=" - " />
A little banged up, but its going to the body shop next week and the denali projectors and some HIDs are going in it too <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ April 21, 2003, 04:46 PM: Message edited by: Chingon ]</small>
Old 04-21-2003, 06:01 PM
sleepersilverado's Avatar
ok so how do you do this with out auto tap? i thought you could use a meter and tap one of the wires with the meter to get the reading.
Thanks Ryan
Old 04-21-2003, 06:10 PM
F8L Z71's Avatar
You can.
1. Just tap the blue wire on the throttle position wire harness (will be the lower plug on the right side of the TB) for the red lead on the voltmeter.
2. Ground the black lead on the voltmeter to something metal.
3. When testing for voltage just turn the ignition key to the on position and flip the throttlebody open all the way against the bumpstop to get your reading. Should read no more than 4.60 volts to be safe.
4. Start gringing the tab as needed while frequently stopping to check progress.
Mine started out at 4.2.
Old 04-21-2003, 06:15 PM
F8L Z71's Avatar
Cool, just found a longer version of what I just wrote if you would like to check it out.
http://www.ls1camaro.net/sections.ph...ticle&artid=26
Old 04-21-2003, 08:31 PM
thanks for the info i realy apreciate it. i have known how to do this for a while but did not know which wire to tap and it was not that big of a priority for me to start a new thread.
Thanks again
Old 04-21-2003, 08:33 PM
F8L Z71's Avatar
NP, hope I helped. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 04-21-2003, 08:39 PM
Ajax's Avatar
Lance, what's up man? This is John. Glad to see you're finally getting that info. you needed. I'm sure I'll see ya around Tim's soon. Later
Old 04-24-2003, 11:49 AM
Formerly one92rs
one03sierra's Avatar
well i got the bump stop grind set at 4.50 before my bat ran out on the cordless. for now it will stay there. plan to go a little more this afternoon. what are the voltages that any of you have set without and with a code <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old 04-24-2003, 02:06 PM
Slammed'99's Avatar
Have you guys noticed any gains by doing this?
Old 04-25-2003, 12:36 AM
MacADaYear's Avatar
im at 4.66 and have no problems so far
took me a while cause I guess fully closed its supposed to be bout .60 so I had to adjust
SloSVO
11-22-2020 07:34 PM
hodge9386
10-25-2015 01:26 PM
lukn4trbl355
10-21-2015 11:19 PM
trxmxzx
09-29-2015 07:42 AM
Quick Reply: BUMP STOP GRIND. NEED INFO ON
