burn outs
#33
ok back the train up here for a second... you have a 212/218 cam, 3K stall, milled heads, i assume bolt ons and such, and you still can't do a burnout? in my opinion you should be doing burnouts with out even having to use the brakes, and doing them for as long as you want. something with your set up is not right.
#37
What do you have in/over the truck bed? If you have something heavy over the wheels, or even a heavy canopy, it can create enough traction to prevent burnouts.
#39
ah, i didn't catch that you have a ccsb. My buddy had the same problem. couldn't get his truck to burnout for the life of him lol. even with water on the ground and all trqmgmt removed and a good tune he still couldn't get it to spin.
#40
Is it a crew cab short bed as in the 5.5 bed or is a 1500hd with a 6.0? I dont remember if u stated or not. A friend of mine has a bone stock 05 crew cab 5.5 bed wit the 5.3 and 342 gears with g80 and it works a lil at first but it gets them going about 3K then it rips the tires. Although I have a couple friends with HD's and they cant powerbreak at all, ecsbs and ccsbs.
