burn outs
#46
well, really the only accurate way to see if it's rich is with the use of a wideband. You could log some data for us though with EFILive. If you enter PE while trying to do a burnout (which you should) the O2's should be reading 850'ish depending on the commanded a/f ratio. If you're seeing 970+ then that bitch is rich (in the words of rick james haha)
#48
1) step one, find someone to help yopu figure out your tuning software.
2) step two, get it dialed on the street
3) step three, take it to a dyno shop with a wideband, and get your PE dialed
4) step four, enjoy your newfound "burnoutability"
cost of dyno time with wideband is around $100 an hour, if your street tune is dialed, it should take you about 30min on the dyno.
MileHighSierra
07-22-2015 11:19 PM
Offroadunleashed
07-20-2015 02:25 PM
