bye bye tq mgt!
11 Second Club
Re: bye bye tq mgt!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by L-EATER:
<strong> I just got LS1 edit and I have spent some time this morning editing my file. I took out the tq mgt, changed the speed limiter, raised the idle, and told it I now have a 6 liter. Can't wait to get home so I can flash it and see if there is a noticeable difference. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">where did you "tell" your pcm that you have a 6.0? why did you raise the idle? cam?
go to your shift tables and change the shift points if you want to notice a difference in it. raise your downshift points just a little too. make sure you do it in the table and not the first window! do you have a scanner?
11 Second Truck Club
Re: bye bye tq mgt!
Texas-The displacement function is under the fuel section and you tell it individual cylinder displacement. I think that helps the pcm calculate the fuel requirements better. I raised the idle because when I went from the 5.3 to the 6.0 it started idling about 100 rpm lower. Sometimes it will stall if you "goose" it in gear then let off. This hasn't happened (yet) since raising the idle. The cam is stock 6.0 liter. I will look at the shift tables but I think Superchips already turned that up.
Even though I zeroed all the tq mgt tables I am still getting timing loss at the hit of the throttle. I can brake torque it in the shop and watch the timing go down to 0 or even less. What else do I need to change to cure this?
Re: bye bye tq mgt!
Bigkid-Where is the abuse mode you are talking about? I set the torque limit to 1000 like I read somewhere but just yesterday I received an e-mail from the ls1 edit mailing list that instructed not to raise it past 639. So I changed that back and altered the timing table but I didn't get to drive it yet cause of rain.
Re: bye bye tq mgt!
Abuse Mode Test is under Engine Cal >> Ignition and is in a little box in the lower right corner.
BTW.. this place has some good info and a nice glossary of terms: http://ls1edit.slowcar.net/links.html
Snake Eater
03-29-2007 11:00 PM
MacADaYear
47
10-26-2004 07:33 PM
