CAI vs Stock w/ drop in K&N
All I run is the airraid tube with the stock box, along with a Aem filter. The stock airbox will supply enough air, and the only restrictive part is the tube due to its silencing baffles. You can always open up the stock box more if you'd like. Like it was said earlier, you wont really notice a difference in performance between any of the intakes though, especially in our trucks.
PT's Slowest Truck
If you decide to switch to the drop in, I'd suggest going with one of the dry flow filter options available...they filter better than the oiled filters and best of all don't need to be oiled. Not sure, but I believe that some claim to flow better also. I'm rockin an Amsoil dry filter with my Volant and I've been very happy with it. I thought that I felt a performance increase when I originally installed it, but that may be because the Volant filter was filthy or it may have been the placebo effect.
Resident Retard
I will say this about CAI.... A few weeks ago i helped a buddy tune his truck with a wideband... Everything was dialed in nicely... At the time he had a volant CAI.... He then switched to a 07+ AEM CAI the tube has a nice gradual curve and is HUGE compared to the volant, also the filter is alot bigger... At the track is was running lean by 7% across the board, and the only thing that changed was the CAI... These were within weeks of each other and roughly the same temps... So 7% difference, i am not sure the exact airflow differences, but since he was lean that means he was getting more air in... More air = POWER...
Just my thoughts.... I would not have believed it but i was there and saw the logs...
PT's Slowest Truck
Tin Foil Hat Wearin' Fool
Something else Corey forgot to mention is when he was helping me tune(well he tuned it actually ) with my volant would take half a mile to get the IATs to drop down close to ambient from the 115-120 it would get to sitting at a light. With an open element(such as K&N or AEM) your IATs are going to drop faster which will keep the computer from pulling that extra degree of timing. May not conern many but its enough for me to plan on replacing my volant once I get some other things taken care of.
PT's Slowest Truck
I think I'm definitely going to consider relocating my IAT sensor (can't afford a new CAI or a used stock air box for that matter lol)
Corey, do you have a PN on that Air Raid intake tube?
