CAI's "All the same." - No!
This has been discussed a lot but i have been doing a lot of reading on CAI's...I know a lot of you think they are worthless, but when going with a cam, full exhaust and a cai will help the cam actually breathe.
Anyways so yes basically they are all the same...but..Wouldn't you want to stay away from aluminum??? I just cant see how after driving for over an hour how it would help the engine...
If not, why wouldn't a setup like the Spectre sold at Autozone be any worse than a 300 dollar K&N setup?...
If you ask me systems like Airaid and S&B have some pretty good designs, but i have heard a lot of good things about systems with a closed airbox (volant/s&b/etc.)...So no technically though they all preform the same purpose, they are not all the same.
Just my 2, what do you guys think?
I prefer my current closed box Volant with ram air, but it honestly performs exactly the same as my old K&N FIPK did, according to my butt-o-meter. I'm sure that my IAT's are somewhat cooler, but an IAT sensor relocation would at least help with the temp signal sent to the PCM, even if the actual air at the filter and MAF is warmer on the open element system
volant box pulls from the fender well so it is technically already cooler air. the ram air tube is to get more of a "ram effect"
you probably wont see anything until 100+mph when the actual "Ram" effect will start to take over....and then again, if your fender is open the air is most likely to push right out of the fender instead of pushing it down your motors throat. it does make sure that the motor isnt getting any restrictions when sucking the air down.
If you want to measure the effectiveness of a CAI system, use a scanner and measure the IAT. The cooler the air the more dense it is with oxygen. Now, where the sensor is located will also impact the IAT reading but the cooler the reading the more potential hp you will gain. However, the CAI setup is only a part of the solution. Anytime you change the air density, the tune in the PCM should be changed to compensate. Also, if you are getting an abundance of cool, dense air into the cylinders you must also efficiently get it out. So, better exhaust scavaging will make a CAI system potentially operate better. Cams, overlap, etc also enter into the equation. That is why one person can dyno a CAI and show little HP/TQ gains and anther will show 5-15 HP/TQ gains.
That said, the effects of RAM on a C5 Z06 vette is a gain of almost 4 HP at 150 mph but at 300 it should add another 100 HP, according to all the engineering types at Z06dotcom.
