cam 112+4
Old 02-07-2007 | 10:47 PM
regency's Avatar
Default cam 112+4
say the cam has a 112+4, can you put it in so that it isnt advanced any, so that it is really hitting on the 112 lsa. Or am i making any sence at all?
Old 02-07-2007 | 10:52 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The +4 is 4* advance ground into the cam. The LSA (lobe seperation) does not change.
As I understand it.
Old 02-07-2007 | 11:07 PM
RWC's Avatar
RWC
Yes, if you retard it 4 degrees it would be the same as a 112+0 or 112 LSA and 112 ICL. If you install it dot to dot it would be a 112 LSA and 108 ICL. And trever1t is right, LSA is ground into the cam and cannot be changed.
Old 02-08-2007 | 12:45 AM
regency's Avatar
i know it cant be changed on the cam itself!! lol!! but retard it that 1, 2, 3, or 4 degrees. seriously what would be the difference between a 112+4 and a 116+0 both being 224/224 with .58x/.58x lift
Old 02-08-2007 | 12:49 AM
negativeswitches's Avatar
difference is the speration angle between the intake and exhaust lobes
112+2 112+4 112+30 is still 112* between the lobes
all the +# does is pre dial in the cam if you didnt per say have an adjustable timing set
Old 02-08-2007 | 02:03 AM
FarmerBeau's Avatar
Sexy Party Mod
You can have a custom ground cam to those specs if you want. I had mine ground on a 110*+0. Otherwise you need an adjustable timing set for those type of adjustments.
2500ZL1
01-25-2016 07:30 AM
lawhitediamante
08-12-2015 01:14 PM
steves86ta
07-28-2015 11:21 AM
WICK3DxGATA
07-21-2015 07:59 PM
projectnightcrawler
07-20-2015 12:30 AM
