cam
cam
ok fellas im cam ignorant and don't know much about em....
i'm starting to look into a cam for my truck these are my mods:
e-fans, 4" CAI, LT's, full 3" exhaust, TB converter, tune, and all the little things...
So what do ya'll think would be the best for my truck?
thanks ,
eric
thanks ,
eric
Originally Posted by $thatguy$
thats was what i was thinking... im in the high 13's right now with my mods .... what you think i will pick up???
Truck addict
216/220 on a 114lsa or try something different go with a 222/222 on a 114lsa. well that is if you plan on spraying nitrous one day. if not go with a 112lsa.
if you want to be a man and break almost new grounds try a 226/226 in that 5.3. i know of one other member on here has done it but i would say get a higher stall converter and gears. what do you want out of it?
keep in mind too large of a cam without heads you aren't going to gain as much imo. my worked heads really woke my 224/224 up. now the intake manifold is the weak link.
give me a call and tell me what you want to do and i can better help you. otherwise you could run 20 different cams and have good gains. but only a handfull will do what you are wanting it to do.
