Cam for a 6.0L?
Old 07-30-2007, 07:42 PM
10 Second Club
Badmire68's Avatar
Default Cam for a 6.0L?
thinking of putting a cam in my 1500HD truck. I want something with some low end torque becouse I use this truck mainly for towing. What cam does everyone else run? Anyone have suggestions and dyno graphs of some of your combo's?
Old 07-30-2007, 10:04 PM
00blackz71's Avatar
I will be ordering a cam tomorrow that Richard at west coast cylinder heads recommended for me to get for my 6.0. Custom grind 208/208 .554/.554 on a 112 lsa. He says that it gives excellent power right off idle and he has one in his 6.0.
Old 07-31-2007, 12:09 AM
ramdaspadhye's Avatar
For a 6 liter, I would go with somthing like a 212/218 high lift cam on like 112lsa. The 6.0 is a larger motor than the 5.3 and will eat up a smaller cam like a 208. Just my opinion...
Old 07-31-2007, 12:35 AM
RandomHero's Avatar
the 208/208 grind seems like a good plan. If you strictly want low end torque then get the 208. If you want a bit more mid/top end then get the 212/218. Either is still a VERY small cam for a 6.0 though.
Old 07-31-2007, 07:55 AM
10 Second Club
WAHUSKER's Avatar
I put Lingenfelter's GT2-3 cam in the 6L that I just dropped in my truck. (207/220, 571/578, 118 lsa) We've had good luck with it in cars. It adds 30-40hp, has great mid range power, & is VERY easy to tune for a good idle. But it doesn't give you that lopey cam sound. The 112 lsa cams people are recommending sound killer, but my exp is they take hours of tuning to get to start and idle right. Might be OK for a race car, but not for my tow vehicle....
Old 07-31-2007, 07:59 AM
OnyxSilveradoSS's Avatar
your realtionship with a tuner is very important.
I have 224/224 @112 and my tuner nailed down the idle pretty easy, BUT the fine tuning is where you get the cam in its sweet spot.
Old 07-31-2007, 03:50 PM
10 Second Club
Badmire68's Avatar
yeah I want this for towing. so it needs to be all low to mid range power increase. Anyone have dyno graphs of any of these cams? I would like to see the power curve on the ones that were mentioned with the exception of the 224 cam. I think it will take it out of the range I'm looking for.
Old 07-31-2007, 07:29 PM
10 Second Club
Badmire68's Avatar
what do you guys think about a stock LS6 cam?
Old 08-08-2007, 12:40 AM
low2001gmc's Avatar
Default 6.0l Cam
hey i have a gm hot cam regrind (219/228 with 525 lift at 112lsa) for $110 shipped. just look at the april 2007 car craft issue. changed plans and have no need for it. for the price of $110, i doubt you can beat it.
rob (low2001gmc@aol.com)
Old 08-08-2007, 08:02 AM
hirdlej's Avatar
I was waiting for you to inquire about that..... I was going to recommend it too. I am running a 01 LS6 cam (smaller than the 02+) in my 4.8 RCSB with a 5spd and 3.73 gears. The cam requires a tiche' of idle tuning (because my motor is small) and virtually no startup tuning. Rework the VE table and Spark table and you'll have a nice cam for that 6.0 that'll tug at your neck from a dead stop and pull great up to 5500 RPM+. The specs on the 01 LS6 cam are 205/215 @ .050 and a .525/.525 lift which is easy on valvetrain parts. LSA is 116.5 I believe. Someone can correct me if I'm wrong. This is a tow rig, you want gas mileage, torque and smooth overall driveability. I wouldn't "over cam" yourself. You'll just be pissed in the long run. If you want go to aftermarket, go with the one of the Vinci cams below. If I had the money at the time I would have put the 080 in my 4.8 but instead got new take out Z06 cam with springs for only $50 so I went that route and I'm very very happy.
080
DUR @ .004" 272*/280*
DUR @ .050" 210*/218*
LIFT .551/.551
OVERLAP 46*
LSA 116* "ULTRA TORQUE"
POWER RANGE 1500 TO 5800
PROVIDES VERY HIGH TORQUE GAINS
GREAT FUEL ECONOMY & POWER
LIGHT THUMPY IDLE
065 DUR @ .004" 262*/ 270*
DUR @ .050" 200*/ 208*
LIFT .502 / .502
OVERLAP 38*
LSA 114*
TOWING & PERFORMANCE
POWER RANGE 1400 TO 5200
HIGH TORQUE
WORKS WELL WITH SUPERCHARGERS
SMOOTH IDLE
Quick Reply: Cam for a 6.0L?
