Cam is in and brought some ticking
single digit dreamer
i was having problems with edit and atap so i just got my pcmcia card from the same guys that make atap. http://www.bb-elec.com/product.asp?s...ialpcmciachart
probably not the cheapest but i was tired of everyeone blaming everyeone elses hardware. this one has 2 ports on it so i car run atap(efilive) and the wideband at the same time and use not have to try and use any usb adapters.
BigKid, see if you can get the advertised duration at .006 and the duration at .200 for your cam. That info should be easily available from FMS or cam motion. Then it would be a little easier to compare that cam with the 212/218 comp high lift. You are going to be happy.
creederado - Well, how does it feel?
lxcoupe
07-27-2015 08:19 PM
Suburban2500
07-19-2015 04:50 PM
