Cam choice
I want to give the truck some pep, its got a dead spot from 72-80 and out the hole, so I want some tq low and something to complement the high end this motor has. Can I tow with a 10" 3200 stall? If so what can I pull?
I'm not a converter expert, but I would think you could still tow a decent amount. A transmission cooler would not be a bad idea.
Also, try using the search feature. There are a lot of cam threads on here to help you get a better idea on what would work for you.
I would go no smaller than an 11" (278mm) converter to tow with, and an aux. cooler is an absolute must if you're going to tow with a verter. Shoot a message to Chris@CircleD and ask him, but I think he'll agree. You will lose a small bit of low end with 220, but I doubt it will be noticable... and you'll blow by 80MPH fast enough that you'll forget there was ever a dead spot there. That's the same reason I got my cam, it seemd to fall on it's face at about 75. Not anymore though
