cam - convert
cam - convert
I have noticed most of the members with cams seem to be in the 210-220
range , and are using 3000 rpm or higher stall . Is there a reason why ?
It just seems like to much stall for a cam with that small of a duration .
WEIGHT
fbodies weigh 3500 pounds.. we weigh from 4500-5500
our cams are small and the stalls are also. Fbodies that run 230+ cams need big stalls so it all balances out back to the weight factor
Originally Posted by 98TAauto
WEIGHT
but I wouldn't consider a 3000 rpm stall small
it was at 2600 but now i have too much tranny fluid so it is only going to 22-2300 for now. i dont have the tools to pump out the excess tranny fluid here at college it wont hurt anything will it?
Originally Posted by SiniSter5.3
understand on the smaller duration cam to help keep the low to mid torq .
no it isn't but the larger the stall the more heat it create in normal driving
conditions and towing .that is what my concern is . I geuss what I really want to know is will my stock convert suffice with a cam around a 220/224 duration?
