Cam/Converter Reliabilty
Hey guys, I am seriously contemplating doing a cam/converter install in my 08 Sierra Denali. I would probably go with a cam in the 220+ duration, .560+ lift range on a 112 LSA. Converter would probably be a 3000 stall. I would also do some LTs. I know doing all this will void the powertrain warranty.
My question is will doing all of this cause my truck to be unreliable?
Will I constantly have to fix different things or is this a pretty simple install that will not cause other problems in my truck?
How reliable have your trucks been after being modded like this?
Thanks guys, this is my DD so I don't want to have a lot of down time with it.
sounds like you've got a pretty good plan! everything you've chosen seems like it will work well together...as far as reliability, just as long as you chose quality parts, you wont have a problem...i just recently installed a cam etc, in my truck and havnt opened the hood other than to show friends and change the oil...the tune will be the biggest part of reliability, get a good tune an you wont have problems...
BTW...my truck is a DD as well
My concerns are that if I do these mods and start breaking other stuff because of them I will be stuck with paying for new parts and not to mention the down time. I've done a lot of research though and nobody seems to have trouble with similar mods. I'm just a little hesitant because the truck only has 15,000 miles on it. Just trying to get some other people's opinions though.
11 Second Club
I'd say if your real worried about it I wouldn't do it. I started modding my truck the day I bought it with 22miles. I drove from the show room to the dyno for a tune. At 650 miles the nitrous went on. At 3500 miles the first cam went in. 56,000 miles, 2 nitrous kits, 3 cam swaps, 3 header/exhaust installs, 350rwhp and beating the **** out of it, its still goin strong...you just just have to ask yourself...do I feel lucky?
Knowing what I know now about converters go with a very HD clutch in the lock up. Either extra plates or thicker ones and also when you retune for it shut off the lock up feature through the tow/haul switch, that will prolong their life. A loose converter with big HP & heavy vehicle is hard on those lutches.
