cam damage-can this be repaired?
Old 07-22-2010, 09:21 AM
sharpshooter's Avatar
Default cam damage-can this be repaired?
I have another LQ4 sitting[drove 10 hours roundtrip Monday it pick up] here ready for my cam,springs and push rods out of my hydrolocked LQ4.
Pulled my cam last night and I found this on only one lobe.It seems like debris is smashed to the surface.
Can this be polished and reused,or do I need a new cam?Also my push rods look good,is their any reason to replace them?
Old 07-22-2010, 09:52 AM
jhe2003's Avatar
I think a new $380 cam will be worth it.
How did you hydrolock your old engine? Mudding?
Old 07-22-2010, 12:23 PM
TX Tahoe Z71's Avatar
Hydrolock story
I would have a machine shop take a look at it, if it's only debris smashed on top and the lobe is still ok, they could probably carefully machine it off and give it a nice little polish.
Old 07-22-2010, 01:17 PM
11 sec. Truck Mod
TIM Z's Avatar
x2 hope it can be polished, wouldnt hurt to have a shop look at it.
Or maybe comp cams can refurbish it?
Good Luck on Your build!!!
Old 07-22-2010, 01:19 PM
Baltimore Whore
Mangled03gmc's Avatar
Its hard to determine the depth of the damage but from the looks of that I would say you need a new cam So the push rod looks good. I assume the rollers on the lifter is equally as bad as the cam??? What you going to do with the engine???
Old 07-22-2010, 02:39 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
If it were mine, I wouldn't even consider re-using that cam, or the lifters.
Old 07-22-2010, 02:55 PM
Resident Retard
BlackGMC's Avatar
the only place i would consider putting that cam is in the trash... i would hate to put everything back together then screw up the engine cause i failed to replace a messed up part.
Old 07-22-2010, 02:59 PM
KySilverado's Avatar
I'm with some. Trash it.
Old 07-22-2010, 03:19 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Send it to me I need some more cams to finish buidling my shop lamp
Old 07-22-2010, 03:26 PM
Baltimore Whore
Riight you no your going to sodimize your self with it, who think your kidding.. :nunchuk1:
Quick Reply: cam damage-can this be repaired?
