Cam debate
Cam debate
Okay, so I'm pulling apart the top end of the 6.0 I swapped into my truck for different gaskets.
The current cam is a 233/237 .579/.568 on a 110 LSA. I have a 222/224 .581/.581 on a 112 I believe. It would take under an hour to swap the cam out.
Thoughts? Swap it or go with what I've already got in there? I think I will be going turbo or blower at some point.
Just looking for some thoughts other than my own.
Definitely the 224 cam IMO. That has proven to be a solid cam that can be tame enough to drive daily and won't kill off too much 'real low end' torque (below 2500 where you'll spend most of your daily drive time). That will be easier to tune and have a better idle and should play nicely with a smaller converter.
motown muscle baby!
I am the guy on there with the 224 in a 6.0L and a 2600 Daco stall, my tuning has finished learning so it is running shoot me a message and we should meet up to compare cams before you swap it out.
I need some track times to see if it lowered my time.
