Cam degree
Cam degree
Hi guys I need a little assistants. I finished installing my cam motion cam and timing set and now it's time to degree the cam. I have the comp cams ls specific degree kit (4942). The problem where I'm getting stuck is comps crank socket, it is suppose to slide over the oil pump drive and turn the crank with that. But I see no way how the socket goes over oil pump drive. It's tight is there a certain way it goes on? It looks like it smaller them the drive gear?? Any help would be appreciated trying to get degreed and button back up
And thank you I installed my last cam dot to dot. Wanted to degree this one!
Really!! Thank u for the catch ima double check that right now!!! Why did I go through the trouble of buying a lsx gen 3 specific kit if it dosent even have the right crank socket! I don't get how they can advertise that? If so if that is the problem what could I do could I call summit and have correct part or would I have to return the kit? I would like to get the right socket somehow
Yea I just doubled checked jegs and saw that too. When I serched that part number and looked at picture it does not look like the socket I have. The one I have looks like that then gets wider with groves look just like it suppo see to go over drive. Mine looks like this COMP Cams 4914, Comp Cams Cam Degree Kits and Accessories | COMP Cams
