Cam guys
#32
Registered User
I got the LS-1 how to bible glued to my windshield so I'm going step by step.
Should I do the ARP Heads studs,ARP Head bolts or GM bolts?
I got GM bolts but if I can get something better and not have to re buy bolts or swap out if I go turbo....
#38
I believe so. You might want shorter rods with the LS7 lifters, they are 0.05" taller than stock. Lots of people are running 7.4" rods though, you will just have more preload than normal. If you mill the heads or run a thinner gasket then you definitely want shorter rods. A pushrod length checker is the only for sure way to know though.
