cam help
Old 03-28-2010, 01:47 PM
low_life96's Avatar
do u have to pull the head to install a cam iv heard u can give the cam a few turns to pump up the lifters an pull it out an slide the other one in with out pulling them is this true???????
Old 03-28-2010, 01:49 PM
SLOXCAB's Avatar
true.
Old 03-28-2010, 01:54 PM
13 Second Truck Club
DV2000NJ's Avatar
This link seems like it could be helpful. Read it.
http://www.ls1howto.com/index.php?article=23
Old 03-28-2010, 02:04 PM
low_life96's Avatar
were that tool work on my 4.8?
Old 03-28-2010, 02:17 PM
low_life96's Avatar
whats the diff between the high lift cam an low lift witch one would i need??
https://texas-speed.com/shop/categor...MID=5&catid=44
Old 03-28-2010, 02:20 PM
DV2000NJ's Avatar
What?
Old 03-28-2010, 03:02 PM
low_life96's Avatar
the cam tool that holds the lifters up
Old 03-28-2010, 03:14 PM
DV2000NJ's Avatar
Yes, it'll work on your truck. You can also use a certain size dowel, with one side ground flat. Do a search on here for lifter tool or lifter dowel and you should find a shitload of info. This has all been covered a bajillion times before.
Old 03-28-2010, 03:43 PM
KDavis04ss's Avatar
TR 220. i believe its 551 lift so all you would need is yellow zo6 springs. makes really good power in a 4.8 and still drives great. dont think you could go wrong with it
Old 03-28-2010, 04:01 PM
Raffman's Avatar
I would call Comp cams and a couple others tech line then someone like Richard at WCCH.
Get a general consensus of a good cam then ask around if someone else has a similar set up and their impressions of it.
Quick Reply: cam help
